PANASONIC Servo, wrong sticker?
medkhai
Sep 2012
bangkok
I have bought a PANASONIC servo model MHMD022G1U
from the Panasonic datasheet it says its 200V, 200W
Once I received the motor it has a sticker which says
PANASONIC
AC SERVO MOTOR
Model No. MHMD022G1U
INPUT 3øAC 91 V 1.6 A
RATED OUTPUT 0.2 kW
Am I reading something wrong or the sticker says its 91V, while the datasheet says it's 200V
Thank you for help
Med
Hi I have a Panasonic Minas A5 servo drive trying to test in free run a Panasonic A6 servo motor, But as there is a mismatch between the motor...
1,674
Hi. i have a Panasonic servo drive running in position control mode. i need to increase the speed of the servo motor. which parameter i can look...
1,560
Hi, Anybody knows the pin out detail for RS232 Communication cable for Panasonic MBDHT2510 SERVO DRIVE (X2 PORT). Model no. of cable is...
2,222
We have a customer that has acquired a couple of these servo drives, but with a limited manual. Google searching brings up a couple of sites, but...
2,251
I am using servo for the first time. We use PLC Mitsubishi FX3U-48MT which has transistor outputs. The servo driver is Panasonic model...
3,833
