Panelbuider help PV550
freepat
Feb 2007
MONTREAL
I would like hide a push button presently on my PV550 Touch. Can i do that with a read value bit.... I know, i can do that with RSVIEW studio (panelview plus), but with this old series???
Short answer: No.
Long answer: No, but there are workarounds in Panelbuilder32. If there's only one button you want to hide, you could create two identical screens--one with the button and one without. Then use the PLC to control which screen is displayed. Another option would be to use graphics in your buttons and have the graphic of one state be blank. I haven't tried this but I think it would work.
What I have done in this instance is make an invisible button by turning off the Visible checkbox. And overlay it with a mulistate indicator, making one of the states blank with black border on black background.
This gives you a pop-up button. Note that the invisible button will work at all times and you will have to program the PLC to disable its function when you have its separate indicator turned to the off state value.
Paul
Hide PB
Yes u can hide a push button. See the attached picture.
Blue ones are Multistate indicators. And I have push buttons underneath them. You can see one in white. Yellow one is a multi state button. With this set up with the yellow button I can select a device and then use F2, F3, F4, or F8 function keys as push buttons to move that device.
Hope this helps u
I just got hit with replacing a PV1000 with a PV1000 plus. Is there an easy way to convert a .pba file to download in the new PV+ ???
3,808
Hello, I need to write the following program in Ladder language, but I could not integrate the Fibonacci sequence into the ladder. Can you help...
150
this a program to send data to barcode printer I want to integrate a new printer in a new machine and i wanted to adapt the old prgram on it but I...
151
52
Hi all, hope you are having a great day, I am in need of your help to create a AOI or program that does this kind of job: I have a IO Link...
26
472
