Tim Ganz
I have a panelview 1000 that I am trying to upload a make a small change and I am having issues connecting with panelbuilder 32.
The panelview is connected by the rs-232 port to a SLC 5/04.
I have cable # 2711-NC2 and Cable # 2711-NC13.
In the config screen on the panelview it has
Max Node 21
Node 2
Baud 19200
I don't see how you would set this up in rslinx? I have linx 2.57.
I have tried to use the RS232 DF1 driver with no sucess using autoconfig and manual and made it a different done from the panelview.
When i try to use the point to point driver in panelbuilder 32 it starts rslinx? Even though i have shut linx down and it is not running in service mode?
What can I do to get connected?
Max Node 21
Node 2
Baud 19200
