PanelView 6 Plus and DataStore
nmk
Dec 2002
38
I added the DataStore active x to the FactoryTalk View 8.0 and have a problem with setting the path for the log file. from browsing other threads on the internet I am not sure if the panel view 6 has to be Panel View Plus CE for the DatasTORE to work? If some one could list the steps needed to set the path for the log file and if I can use the PanelView 6 plus(not CE version)? Finally how to retrieve the log file? I am using win 7 laptop connected to a Ethernet swith that host a compact logix PLC anf the Hmi mentioned above.
Thanks:D
For the original PanelView Plus platform (5.10 and earlier) you needed the "PanelView Plus CE" model with access to the CE desktop in order to install and run ActiveX objects like the DataStore Plus.
For the PanelView Plus 6 and later hardware and operating system, support for ActiveX is built into all of the models. Follow the directions for using DataStore Plus with the PanelView Plus 6.
The two principal methods for retrieving the log files created by the DataStore object are to use a USB drive with a batch file, or to enable and use FTP.
I have come to the conclusion that ME datastore plus is not very reliable at doing what it is supposed to do. Please prove me wrong so that I can...
2,330
i need help in getting Datastor plus to create the log file in the location as configure the activex object. i have an existing project that i...
3,117
What I have is a machine that tests a product. When we start a test we need to record some pressures and cycle times. We enter in the product...
2,490
I'm at a loss here and hoping someone else has seen this: Background: We've got two identical machines on our floor (we'll call them machine A &...
68
121
