PanelView Audit Log
Alan Case
Apr 2002
Wagga Wagga
1,268
Hi.
Can anyone explain the reasoning behind why since version 9 in the Panelview 6/7 the audit logs that can be exported (CSV format) have the time as UTC not local PV time.
Makes it hard to explain to people that the time shown is not correct, they have to convert to local time.
Regards Alan
Unfortunately I don’t have an answer but have experienced the same thing, the dates are wrong in the history log as well if you use the export feature.
My workaround was to key a few know buttons and alarms, record the date and time then work back the offset to know the actual time and date.
Please post if you do find anything. I haven’t been able to locate anything in the Knowledgebase.
If you push them to SQL instead w/ the UTC offset, as of 2016 you can use AT TIME ZONE to easily convert to your local for reporting.
select timestamp AT TIME ZONE "timezonehere"
The user manual just says that in v10 and later, the log features will use UTC for timestamps, and does not give a reason.
My guess is that one or more major customers complained about the terminals not correctly or easily supporting daylight saving time or time zone settings, so they switched to UTC so that those would not be a problem.
Hello, I was wondering if anyone could let me know how to change the audit trail messages language on Factory Talk ME. I am currently working...
464
Hello, I have followed the "On_board Audit Demo" sample in FactoryTalk View Studio ME to add the functionality of exporting the Audit, Alarm, and...
1,148
Hi all, I am trying to get the audit trail information from a PV Plus7 application to a network share, the data is currently going to a thumb...
1,899
89
Hi Everyone, Currently we have three plants running with Controllogix PLCs (L72, L73, L74). In each of these plants we have 2 FTView SE...
56
