Panelview Component 1000 to SLC 5/03
ndzied1
Aug 2002
Chicago, Illinois
2,857
We have a system with a Panelview Component 1000 and an SLC 5/03 on the floor.
Does anyone know if the Component screen can be connected directly to the DH-485 port on the SLC 5/03. We have it on the RS232 port right now but our DH-485 programming cable (1747-pic) won't work with adapters.
We'd like to not have to swap the cables on the PLC to make program changes.
Thanks,
Norm
You haven't said which port you are currently using on the C1000, the RS-232 (9-pin) or the RS-422/485 (5-pin) port?
Also, how far apart are they?
A) You could use a 2711C-CBL-AB03, which is an RS-485 (5-pin) to RJ45 cable. This allows a direct point-to-point connection between the C1000's RS-485 (5-pin) port and the SLC 5/03's Ch1 DH-485 (RJ45) port, as long as the C1000 and SLC 5/03 are within 2 meters i.e. same enclosure. If you are not already using the C1000's RS-485 (5-pin) port, then you would have to reconfigure your project to use this port instead.
B) Alternatively, and as a replacement to the 1747-PIC, you could purchase a 1747-UIC, which is a USB to DH-485 interface converter. The 1747-UIC has both an RS-232 (9-pin) and RS-485 (RJ45) port (switch selectable) for connection to the controller. This would allow you to connect to either port of the SLC 5/03. The 1747-UIC does not come with any cables for making the connection to a controller. So, to connect to the Ch1 DH-485 (RJ45) port on the SLC 5/03, you would need to purchase a 1747-C13 (RJ45 to RJ45) cable, if you don't already have one. Some sellers offer both packaged together.
Going forward, I would recommend option B.
Regards,
George
Dear all i use Panelview component C1000 in my project i wonder how can connect it with Rslogix 5000 to simulate it without hardware for testing...
1,996
Hello All Automation Experts I m using panelview component 1000 in one project where i have to devloped all HMI screens offline with its...
3,986
3,662
I have one project in which i m going to use "panelview component 1000" presently i will get panelview after 10 days i want to create offline HMI...
5,254
Does anyone have access to a programmer's manual for this? Specifically, I am looking for instructions for the advanced toolbox objects such as...
1,042
