PanelView Message Display Colors
Pegleg
Jan 2022
SoCal
Hello,
I have been lurking here for awhile and can usually find the answers to my problems. I'm doing my first PanelView application using FactoryTalk View Studio, and I'm struggling with finding the answer to this one. I decided it was time to join!
Is there a way to change the background and text color of a Message Display based upon the control tags integer value?
I would like to have our regular operating messages with green backgrounds, warning messages in Yellow, and faulted messages in Red.
Welcome to the PLCTalk forum community !
First, let's be sure we're talking about the same thing. When you say "Message Display", do you mean a Local Message Display object, or a Multi-State Indicator, or something else ?
In general, the background "panel" color of a Message Display is configured in the General Properties tab, and does not have a Connection to a PLC tag.
The lists of Messages are nothing but a table of Values and Message Text; there are no color, font, or format settings in the Message List files.
That leaves Animation as a way to change the appearance of those objects, and as you've probably seen, the only Animation that can be applied to a Local Message Display is a tag to control the visibility.
So in general, you could have three overlapping Message Displays of different color backgrounds and purposes (operation, warning, fault) but you can't have the same display with a different color depending on the tag value that drives it.
A Multi-State Indicator, or a List Indicator, are different sorts of objects: every State of those can have its own text and color and font. But they're harder to edit in bulk, compared to a Local Message object.
Thank you Ken.
I was playing around with both Local Message Display and Information Message Display. They appear to have a similar type of setup.
The Multi-State Indicator will do what I need.
I use PanelView Plus 7 Graphic Terminals Model: 2711P-T10C22D8S-B PLC: Compact Logic 1769-L36ERM Tag ER[4].8 -> ON, the message is "1046 Abnormal...
1,763
Hi guys, I'm working on a PV+ with PLC5. I need to shows the alarm message of the system on the PV+ (DH+). When alarm 1 is activated, the PLC...
6,792
Hello everybody, I have to display a message on panelview 1200 from plc5/20E when a digital input changes its state. The message has to appear...
3,388
SLC5/03 & PanelView 300 Message Display/Function Key Process Can anyone explain the display and Function Key program flow between the SLC5/03 &...
8,912
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
138
