gomerpyles
So i've read a couple forum posts on gaining access to the Terminal settings once the panelview is up and running, but none of them have worked for me.
I'm currently working on a Panelview plus 1250 it has 6.0 version on it currently.
Upon startup when its testing its ram/cpu/hardrive and what not a WHITE box never appears on the bottom left hand corner of the screen. when i just press at the spot anyways and avoid the fatal error stuck keys it still just boots up normally.
I've plugged in a dell keyboard to the usb inputs (there are 2) and i press CTRL+alt+Shift+windowkey the whole time its booting up it still boots up normally.
I do not want to reset the panelview, i really need to understand how to operate into the terminal settings in case I'm out in the field needing to change an IP address from the panel. ( i know about creating a new runtime with a go to config mode button)
Feedback welcomed.
THANKS!
Feedback welcomed.
THANKS!
