Opening PanelView Application with RSView Studio?
Feb 2008
Walnuc Creek, CA
31
Hello,
I just received a PanelView application in the form of a .PVA file, and would like to take a look at it. I have RSView Studio installed and was hoping that I could open the file using this. I've never actually used PanelView before, and so this is my first stab at it. Any tips/help would be greatly appreciated.
Thank you in advance.
The PVA is a compressed form of the application. You can't just unzip it though.
Start RSView Studio. Don't try to load a project. Got to 'Tools - Application Manaager'. There choose 'Restore Application'. Find the APA file and let it do its thing. Then you can go to 'File - Open Application'
When done modifying the application create the APA backup by going back to the Application Manager and choosing Backup Application.
THE APPLICATION MANAGER IS THE ONLY WAY TO WORK WITH APPLICATIONS. Don't try to create, delete or move the folders by yourself.
Thanks for the response. You say to choose the APA file when doing the 'Restore Application'. My application is a PVA file. Is there a way to convert PVA to APA?
Thank you.
.pva files are files that have been uploaded from a panelview (not a panelview +) PVA's are opened with panelbuilder 32 software not rsview studio.
*unless someone here has figured out a way to open panelview apps in studio???
There is a conversion utility in studio to convert PV applications to PV+. I have only played with it once and am not at my work computer right now to give you good instructions on how to use it. If I remeber correctly, it was pretty self explanatory once you found the the utility.
I believe once you open studio, chose new program, give it a name. When it opens up look thru the drop down menus to find the convert PV application to studio.
File > Open
Then New and type in an application name
Then Import
(Unless its just looking, if its a real conversion your doing then set the comms before importing, ie if the app is dh485 then load the appropriate driver up in rslinx enterpirse before importing.)
So i've read a couple forum posts on gaining access to the Terminal settings once the panelview is up and running, but none of them have worked...
2,890
Hi, Im tying to run a new project on a PV+ 1000 but it fails to load because of memory space. I added a CF card and moved all the applications to...
4,619
We have a customer using PanelView 1200, we are given a backup program (from customer CD-ROM) of the PV1200. I've installed a DOS based program...
7,295
I have an Allen Bradley temperature switch that I am trying to use in studio 5000. I am getting the message "Unable to interpret the IODD file"...
74
Very similar issue as the last post I had here with communicating our Linux Gateway to an AB CompactLogix controller. I have assigned a gateway...
175
