Issue with port 44181 Opening
Cotafam
Dec 2023
Georgia
30
Very similar issue as the last post I had here with communicating our Linux Gateway to an AB CompactLogix controller. I have assigned a gateway address to the controller and assigned that same address to our Linux Gateway. Able to ping with no problem only difference here is that I have not power cycled the PLC as they are currently running. There is also no switch involved on the PLC side looks like the ethernet cable is connected directly to port one on the controller. Any ideas before I power cycle? This unit is only a LAN set up fyi.
PLC is going through this switch as well. Could have firewall? TrendNet.
Issue actually turned out to be me using .255 as the last octet on our Linux Gateway. Once it was switched to .74 we had no issues speaking with the port and receiving data; did not matter about the messaging check boxes.
Rockwell Tech Support seemed to have hit a wall with this question. Already updated the version to 5.00.13 per their suggestio but am still...
244
I had a student fooling around with settings tonight, and now when I try to print a program ladder, each rung prints on a separate sheet. Too many...
360
Hi all. I have been an IT worker for many years. Most of it in server support and networking. However I am VERY new to the PLC environment, but...
2,121
Hi All, I have an issue with LogixDesigner v27 running on Win10, with Compatibility to Win XP SP3. Since that was the only way I had to run it...
1,490
Hello Everyone, I have a Redlion DSPSX000. When I first powered it on I was able to Download the configuration in it with USB. After That I...
1,468
