FactoryTalk Activation Manager - Dynamic Port issue with firewall
harryting
May 2002
Puget Sound
2,595
Rockwell Tech Support seemed to have hit a wall with this question. Already updated the version to 5.00.13 per their suggestio but am still having issue with flexsvr portion of the Activation Manager.
Initially, we opened up a port used by flexsvr.exe and it worked for a while. The next time a different port was used and it fails. Is there a way to force flexsvr.exe to use a specific port every time?
ETA: this is RA's list of ports FactoryTalk Activation Manager firewall ports and rules.
Flexsvr Server activation uses dynamically allocated ports, and these cause issues with firewalls that only allow a list of specified ports.
I have got this working with IT at a couple of large sites in the past and put together the following guide to document what was done.
Hopefully it's still current with the later versions of Activation Manager.
The guide is based on the information contained in the following Tech Notes:
ID: IN3991 | Access Levels: Everyone
FactoryTalk Activations in advanced network environments
ID: QA10319 | Access Levels: Everyone
Changing TCP port number in FactoryTalk Activation Manager
  • Activation Manager Setup Dedicated Network Ports.pdf
Thanks Mike. that worked. I only apply some of the stuff in there since we already opened the port for the code meter but that note is very helpful. We only did this edit in the *.lic file.
Code:
VENDOR flexsvr PORT=XXXXX
/rant warning
Rockwell still have not got back to me. Their tech support seems to be shell what it used to be. Why couldn't they draft up something like Mike just did here when they already have roughly the same info spread in 2 or 3 different technote? Are they just run by financial wizard whose claim to fame is make more people forced to use their subscription model?
Hi Folks, who know why after start FactoryTalk activation manager V4.03, click "Get New Activations", it displays Is not I appreciate with any...
65
Hello all, I have the misfortune of needing to support some old firmware version 1756 controllogix machines in rslogix 5000, as well as some...
971
Does any of you configure FactoryTalk activation Manager to share license through a VPN connection? We have a spare laptop that is used as a...
1,792
The plant I work in uses Rockwell software primarily. We serve licenses to users with Factory Talk Activation Manager using a server running...
1,591
Hello everyone. I am very new to PLCS (I was introduced to FactoryTalk today.) My boss has asked me to install FactoryTalk Activation Manager on...
1,788
