Factorytalk activation Manager through VPN
Feb 2022
Québec
Does any of you configure FactoryTalk activation Manager to share license through a VPN connection?
We have a spare laptop that is used as a server to share a floating license locally for two of us. When we have a project that uses studio 5000 or any Rockwell product, the tech borrows the license for the time of the service call connecting locally to the network. This works fine. But sometimes, it is not possible to connect locally to the network to borrow or return the license for someone else to use it.
Is there possible to connect to that server laptop from another network through a VPN connection for example to share the license?
I try to setup an OpenVPN on my router. I can ping all the laptops on the local and public networks, but I don't see the laptop in the network selection in factory talk activation manager.
since you already have a server. once you setup vm machine, you can borrow the license then copy your vm to each laptop.
Go to Manage Activations tab -> Update Activation Search Path -> click on Add Server, then enter the machine's IP address.
Launch Studio 5000.
As long as the license host isn't running any instances of the licensed software, you can just launch. No need to use the borrow/return mechanism.
Launch Studio 5000.
Just figure out that we can manually input ip adresse :eek::eek::eek:
Thanks !!!
Hi Folks, who know why after start FactoryTalk activation manager V4.03, click "Get New Activations", it displays Is not I appreciate with any...
84
Rockwell Tech Support seemed to have hit a wall with this question. Already updated the version to 5.00.13 per their suggestio but am still...
254
Hello all, I have the misfortune of needing to support some old firmware version 1756 controllogix machines in rslogix 5000, as well as some...
1,000
The plant I work in uses Rockwell software primarily. We serve licenses to users with Factory Talk Activation Manager using a server running...
1,609
Hello everyone. I am very new to PLCS (I was introduced to FactoryTalk today.) My boss has asked me to install FactoryTalk Activation Manager on...
1,802
