PanelView / PanelBuilder upload error 1012
Ed Knights
Sep 2015
Cambridge, UK
Hello, anyone had a similar experience?
A customer has an old panelview600, it is faulted, but is communicating and they desperately need to recover runtime from it. Panelbuilder will upload a .PVA file, but displays the following error when it gets to the 'verify uploaded application' stage;
"Error (1012) - Error while scanning for application file CRC."
What is not clear to me is if a) the application file is corrupt and so checksum does not match, b) the checksum is not bing found.
I am hoping it is b), but cannot find this error 1012 in PanelView or PanelBuilder manuals. I am also hoping that I just need an older version of PanelBuilder32, maybe one that doesn't even attempt a CRC check!
I am using PanelBuilder 3.82, FW on the terminal is 3.4
Photos and uploaded .PVA attached.
Has anyone had a similar experience?
Thanks in advance
  • _PV38.zip
Any chance you could use a memory card to get the program off? That's my preferred method of program transfer on PanelViews.
Hi, good shout but the screen is defective unfortunatley. Not aware of a way to force a copy from HMI EPROM to flash card via linx/PB32/PFT?
i had this happen once.
the issue was that the panelview terminal was so old and i was using a newer version of panelbuilder and rslinx.
i had to use an older version of rslinx and panelbuilder to upload the program.
regards,
james
regards,
james
Really?? Awesome thanks James, will see what old versions of PB32 I can get my hands on.
3.82 is the only PB32 version I can get my hands on, it the only 1 rockwell wants to let me download too... better raid the customer's software cupboard. You don't know roughly what version you had to revert to to get your old .pva file open do you?
Cheers
Ed
Edit - just got hold of 3.50 also and same story - cannot verify or open the .pva file
I tried to open the pva file with version 3.83 and got complaints about the file possibly being corrupt. This version does not list anything in the help file for Error 1012 either.
There is a Techconnect article that references Error 1011 and advises to try to upload using an ATA flash memory card.
version 3.82 has some bugs, version 3.83.01 is the current version if i am not mistaken. i had to go back to rslinx 3.41 and panelbulder 3.6???
i kept all the versions of ab software for such occasions and it has been 15 years since that happened, so the panelbuilder version may be off, but the rslinx version is correct.
regards,
james
Hi all, I'm in the process of upgrading a PanelView1200 HMI program to be developed in FactroyTalk View Studio. The filetype for PanelView 1200...
283
Hello. Before I get chewed out, I did do a search on here for some SL505 passthru help. I noticed there was a small handful of information on...
3,574
Everything works except alarms. The plc 5 uses a integer file and a number is moved there corresponding to the fault. 1-79 The text from PB...
1,149
Hello Guys I was chatting with the tech connect chat live from AB, but it tells me there is not a tool for upgrading an app from Panelbuilder to...
2,757
Hi everybody! I recently found these forums and they have been a great help, you guys have got me through quite a bit! But, today I'm unable to...
3,640
