PanelView Plus 1000/Alarms
kpcmaint
Mar 2016
illinois
I have a PanelView Plus 1000 Firmware 5.10. The problem is, when testing app in FTVS 8.1 everything works correctly. Downloaded to panelview and alarm and alarm history doesn't work at all. Any ideas????
I found out that when you drop an Alarm window on a screen that by default it has no columns configured. You have to select it, then the menu bar on the top allows you to configure it.
So there are not any specific settings on the terminal related to displaying or not displaying alarms. But there are a bunch of settings in software.
When you say it works on your PC but not when downloaded, that implies it is a communications setting and not an issue with alarming itself.
Are other things working on the PanelView? Does it display updated data from the PLC(s)? Or are you getting errors or question marks where you should see data?
OG
All of the other screen function as they should. I do have the alarm box checked in start up. I agree that it is software related, but have not found the answer. An older version (created in 5.0 and converted 32bit/64 bit for 8.1) displays alarms, but I have not found the difference between the two mer's.
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
140
Hi everyone, I've been tasked with creating a basic HMI for commissioning purposes for two pumps on a AB Panelview Plus 1000, 2711PRDT10C. I have...
2,907
im tring to find out if i have a bad power supply for my panelview 1000 plus. does anyone have the pinout for the 10 pin connector on the...
1,864
I need an X/Y plot to visually represent data o a roundness gage I am designing. ActiveX ME Chart Control UDT seems broke. Any advise one how to...
665
Hello Everyone, I hope we are all good today! I have a project from 2015, and the customer is locked out of the HMI. They do not know what the...
1,978
