Panelview Plus 1000 and 600 Questions
tadams73
Nov 2008
Tennessee
25
Im new to panelview Plus 1000 and 600. What software and cables do i need and will i be able to upload modify and download tho orignal files from these. Thanks
Panelview plus 600 & 1000
in both the panelview u have to use "factory talk view studio" softawre!!
and u can use ethernet or serial cable (both side 9 pin female port) (cp3)
:rolleyes:
Thanks & Regards
Shirish Shrivastava
One catch, the file in the screen will be an ".mer" file which you can not edit.
The edit-able (non-compiled) file will be an ".acd"
If you don't already have the original, you will have to start from scratch to make modifications.
Although you can download the ".mer" file and keep it as a backup in case the screen dies.
I think this is a typo...for the PV+ it would be .apa
The .acd is RSLogix5000 I believe since I don't work with it that often.
Also, there is a PDF floating around that tells how how to extract some information out of the .mer file but it doesn't get it all but it may be a start if you don't have the .apa file.
Hope this helps.
I wouldn't use a serial cable, just buy a compact flash card and a reader. You can write a batch file to do the copy for you so you don't have to navigate the menu. Much faster than a serial cable.
I use the following in a batch file to backup what is currently in the panelview and load my new app. Keep in mind, we always keep only one file on the terminal and we always keep it the same name. It's kind of crude, but it works.
Code:
REM    Create a directory on the flash drive
REM    to back up the original file
mkdir \"storage card2"\original
REM    Copy the original file to the flash drive
copy \"storage card"\"rockwell software"\rsviewme\runtime\*.mer \"storage card2"\original\
REM    first get to the proper directory
cd\storage card\rockwell software\rsviewme\runtime\
REM now delete the old version of the mer
del /f /q "*.mer"
REM    copy the new version from the CF card (top level)
REM    the file we are going to copy can not have any spaces
REM    in its name
copy \"storage card2\"*.mer
Call \windows\rebootsystem.exe /y
The reboot at the bottom doesn't work with 600's.
I should also mention that the batch file should be called "autorun.bat"
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
138
Hi everyone, I've been tasked with creating a basic HMI for commissioning purposes for two pumps on a AB Panelview Plus 1000, 2711PRDT10C. I have...
2,902
im tring to find out if i have a bad power supply for my panelview 1000 plus. does anyone have the pinout for the 10 pin connector on the...
1,862
I need an X/Y plot to visually represent data o a roundness gage I am designing. ActiveX ME Chart Control UDT seems broke. Any advise one how to...
663
Hello Everyone, I hope we are all good today! I have a project from 2015, and the customer is locked out of the HMI. They do not know what the...
1,974
