Panelview plus 1000 compact download problem
Matthewn
Mar 2010
Galway
Hi All
I'm having an issue downloading an application to a panelview plus 1000 screen. I've used factory talk view studio ME to develop the program and am using a serial 2711-NC13 lead to download to the target. I have added a DF1 driver within rslinx enterprise and double checked all comms settings on terminal etc. Now, the problem starts, rslinx does see the target, but does not recognise it as a device. After browsing the DF1 network the panelview plus compact appears below in the tree. Then, when I select this as my target device it reacts like it is another network and starts browing at this tree level. Also, the message "select a different path - Serial DF1,Panelview-Plus compact cannot be used" is shown in the bottom of the screen. Am I doing something terrbly novice wrong? I've been at this 2 days now, beginning to test my patience! Any help would be much appreciated.
Matthew
Hi All
Matthew
What version of RSLinx are you running??
The Compact series is relatively new.
Hi bkottaras,
I'm using factory talk view ME ver. 5.00 CPR9, im using rslinx enterprise that runs on this platform.
Matthew.
This may help.
Set up for RSLinx enterprise.
Target device should be your PLC.
(Ignore the multiple Cpus in the attachement).
Thanks for the quick reply bkottaras.
I'm still having issues though. In the local setup, I have added a DF1 driver, i'm connected to the panelview and have set all comms correctly there, I think anyway! When i start browsing DF1 it does find the panelview but it doesn't let me select this as my target device, it branches down once again showing default drivers.
Matthew.
Hi Mickey,
Thanks for the reply. Would I be correct in saying i'm usig the wrong development software - factorytalk view studio ME 5.00?? Or do you have to set the target as a "compact" somewhere in project settings?? The only set-up I had to do under "project settings" was display size. Is there something i'm not seeing? Thanks.
Matthew.
Hi All
Matthew
You should be able to see the unit.
not sure if yoour Linx is up to date or it is a compact issue or simply a comms issue.
Maybe, see pictures below from the manual.
FYI, I'm not a PanelView Plus user.
I'd look at what Mickey has posted.
Seems to be the issue.
As I have already said, compact is relatively new, haven't used one yet nor planning on using one in the future.
Hi Mickey,
Matthew.
Current version is v5.10 for ME.
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
138
Hi everyone, I've been tasked with creating a basic HMI for commissioning purposes for two pumps on a AB Panelview Plus 1000, 2711PRDT10C. I have...
2,902
im tring to find out if i have a bad power supply for my panelview 1000 plus. does anyone have the pinout for the 10 pin connector on the...
1,862
I need an X/Y plot to visually represent data o a roundness gage I am designing. ActiveX ME Chart Control UDT seems broke. Any advise one how to...
663
Hello Everyone, I hope we are all good today! I have a project from 2015, and the customer is locked out of the HMI. They do not know what the...
1,974
