PanelView Plus 1000 fail to go to specified display in remote display control tag
JDFP
Feb 2020
San Cristobal
Greetings.
I have a project in PanelView Plus 1000, that cosist in datalogging some variables using the ActiveX object DataStorePlus. For that object to work properly and not losing any data it most be in an always active screen. The way I do this is by creating a screen and configure it on top and cannot be replace and set the screen cordinates outside of visble area.
When this first screen startup it execute a macro that change screen using the remote display control feature of HMI.
The problem I'm experiencing is that the HMI gets stuck at the first screen even if the macro is executing.
I've done several tests and have found these elements:
1. The macro is executing because I can see the remote display control tag changing in the PLC.
2. When I simulate the HMI program it works all fine.
I'm thinking of a possible solution a firmware update, but I have no idea the source of this problem. I would appreciate if someone could help.
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
133
Hi everyone, I've been tasked with creating a basic HMI for commissioning purposes for two pumps on a AB Panelview Plus 1000, 2711PRDT10C. I have...
2,897
im tring to find out if i have a bad power supply for my panelview 1000 plus. does anyone have the pinout for the 10 pin connector on the...
1,859
I need an X/Y plot to visually represent data o a roundness gage I am designing. ActiveX ME Chart Control UDT seems broke. Any advise one how to...
661
Hello Everyone, I hope we are all good today! I have a project from 2015, and the customer is locked out of the HMI. They do not know what the...
1,971
