PanelView Plus 1000 not communicating to ControlLogix PLC
Syrist
Jun 2006
Kitchener
17
I have a PanelView Plus 1000 terminal and I'm having trouble communicating to a simple ControlLogix PLC over ethernet. I have the PanelView's ethernet IP and subnet set (static) and the rslinx enterprise path shows the communication path to the PLC (extracted from another working PanelView). Yet, it's not communicating.
I'm able to ping the PV and get a reply from some other computer on the network.
Any ideas?
-Pete
Post the actual error message that appears in the Diagnostic Display. Maybe this is communication, and maybe it's a problem with the Shortcut definition in RSLinx Enterprise, or maybe something else.
Make certain there are no IP conflicts by isolating the network or disconnecting each node during a PING -T test from your computer.
Any ideas?
-Pete
Was this a working PV+ and stopped communicating after a change, or a new install.
If the install is new, you need to select the box as below only for the initial download, assuming the local Rslinx Enterprise path has been set-up in the Target
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
138
Hi everyone, I've been tasked with creating a basic HMI for commissioning purposes for two pumps on a AB Panelview Plus 1000, 2711PRDT10C. I have...
2,903
im tring to find out if i have a bad power supply for my panelview 1000 plus. does anyone have the pinout for the 10 pin connector on the...
1,863
I need an X/Y plot to visually represent data o a roundness gage I am designing. ActiveX ME Chart Control UDT seems broke. Any advise one how to...
663
Hello Everyone, I hope we are all good today! I have a project from 2015, and the customer is locked out of the HMI. They do not know what the...
1,974
