PanelView Plus 1000 The Item is no longer available problem
1933833
Mar 2022
Quebec
Hello,im a student and i have to do a project using a Panelview plus 1000.I have configured my device shortcuts with the right PLCs in design and runtime.When i use the Application on FactoryTalk View runtime on my computer everything works fine but when i download the program in the Panelview i get the error ''The Item is no longer available problem''.After some research i found that the problem is probably a communication problem but i think my shortcut is ok and it still dont work.
can someone help me thank you very much.
273637373_532702291603466_8304852057099353943_n.jpg 273491992_654309372354216_3216448380238626478_n.jpg 273736623_368494724855635_1591998869070524432_n.jpg 274027152_467546515025243_6947882914359039613_n.jpg 274253116_997856731146687_3818106983830445305_n.jpg
It looks like on your laptop you are configuring the runtime and design targets for Compact_Logix_11. Make sure you have Guard_Logix selected when making those changes. Don't forget to Apply the changes, and create a new MER. I agree with Engineerj22, delete the shortcuts you don't need. You may also be better off replacing the communications when you upload your MER. Under "When application runs:" select Replace communications in the ME Transfer Utility.
(y)
(y)(y)(y)
Thank you all for you answers.After some research we found out that the project the other students did last year was only using a GuardLogix but this year we used 4 ControlLogix instead.The panelview was compatible with the processor of the GuardLogix but not the ControlLogix.
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
137
Hi everyone, I've been tasked with creating a basic HMI for commissioning purposes for two pumps on a AB Panelview Plus 1000, 2711PRDT10C. I have...
2,902
im tring to find out if i have a bad power supply for my panelview 1000 plus. does anyone have the pinout for the 10 pin connector on the...
1,862
I need an X/Y plot to visually represent data o a roundness gage I am designing. ActiveX ME Chart Control UDT seems broke. Any advise one how to...
663
Hello Everyone, I hope we are all good today! I have a project from 2015, and the customer is locked out of the HMI. They do not know what the...
1,974
