PanelView Plus 1000 Touchscreen
Georgetwo
Oct 2006
Ohio
First time user of this product and I am looking for what defines the size of the touch cell. The older PV standard had a defined cell size. The end user is looking for a matrix of buttons 8 horizontal and 4 vertical, plus five displays for feedback signals horizontally and 5 more button for moving to another pages of simliar format horizonally across the bottom on the screen.
George
On a 10-inch screen
I did a quick look through the PV+ User's Manual, but did not find a reference to touch cell size. If I recall correctly, with the PanelView Plus, the touch area for a button is determined by the size of the button, and there may no longer be touch cells in the PanelView Plus per se.
There is a button property that allows you to create a "deadband" of sorts (measured in pixels) around the edge of each button. That can help keep a user from accidentally pressing two buttons at the same time when they are spaced close together. In this case, the non-active border makes the operator have to press closer to the center of a button for it to activate.
However, the bigger (smaller?) issue may be your customer's request. IMHO, it would be difficult to create a useable touchscreen with that many elements on a larger (17")PC monitor, let alone a 10-inch HMI screen...
Rick
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
148
Hi everyone, I've been tasked with creating a basic HMI for commissioning purposes for two pumps on a AB Panelview Plus 1000, 2711PRDT10C. I have...
2,923
im tring to find out if i have a bad power supply for my panelview 1000 plus. does anyone have the pinout for the 10 pin connector on the...
1,865
I need an X/Y plot to visually represent data o a roundness gage I am designing. ActiveX ME Chart Control UDT seems broke. Any advise one how to...
669
Hello Everyone, I hope we are all good today! I have a project from 2015, and the customer is locked out of the HMI. They do not know what the...
1,988
