My PVP7 (performance) Hmi keeps losing connection to plc.
Plc is L33ER v31.011, Switch is Stratix 5400, also on the network are two EIP leak test machines. I've used this setup on several other machines just like this before and never seen this.
I've triple checked for ip conflicts, swapped enet cables, and reset everything to factory defaults; nothing works.
After a power cycle, the Hmi seems to work just fine, then the next morning, no connection.
The strange thing is, when all is connected and running fine, I can ping the plc and LTs, but CANNOT ping the PVP7 hmi.
I'm drawing a blank at this point. Any suggestions?
