Panelview Plus Multistate Indicator Help
Leery24
Mar 2018
Carlisle
This is my first post and my first time programming a panelview plus 1250.
Im looking for some help with something I am trying to do with multistate indicators.
Im basically using these to display some information. the problem i have is that in this scenario the messages I want to display are changing quite frequently and I have around 150 of them so it can be quite a task to update them all.
I was just wondering if anyone knows of an easy way to update all of these tags at once. They all show the same messages but are linked to different tags.
Any help will be much appreciated :D
Edit List Indicator XML outside of FactoryTalk View Studio
32140 | Date Created: 06/08/2005 | Last Updated: 01/10/2018
Access Level: TechConnect 
I have found some information on how to do that.
Thanks for pointing it out.
:D
Using Factorytalk view ME and RSLOGIX5000 I am trying to use a multistate indicator on my Panelview plus that will become visible and display a...
10,554
How do you determine what a multistate indicator is going to do when it is pressed? I have an existing application with a gotoDisplayButton...
12,461
I need a multistate indicator with a trigger type LSB that will span four integers. So, I created it with the connection tag "MESSAGE" assigned...
4,078
The application looks fine in the test run at the development node(my computer), but when transfer to the Panel View I can see some of the labels...
4,765
91
