PanelView serial printer multi-line application
Ken Roach
Apr 2002
Seattle, WA
17,482
This topic came up in a related thread, and I'm unilaterally moving it to a new thread. Forum etiquette aside, that thread was for an OP who was starting to understand the basics of SLC-500 and PanelView port configurations, and this is a moderately advanced PanelView application question.
The original post (new topic at Post #10, user Caveman): http://plctalk.net/qanda/showthread.php?t=77606
The original question:
It is it possible to send a receipt with multiple lines of variable data to a serial printer on a t10c3 firmware 4.XX terminal?
I am able to send just 1 line
I'm not an expert on serial printing with the PanelView Standard terminals, but I've used it a little in the past.
Are you using a Print-Only object, or an Alarm for which the Print box has been checked ?
How many lines are you planning to send ? Does the printer require both Carriage Return and Line Feed characters, or just one of the two ?
Hi All. I have AB PLC Micrologix 1500 and HMI PV600. In factoryTalkView ME I have installed RSLinx Enterprise and I have setup communication...
2,597
So a customer with an old Parker touchscreen wants to replace it with an AB Panelview 1000 unit. The Parker has two serial ports that are...
1,563
I've followed all the steps from Rockwell to use the KepWare UCONN driver to transmit ascii data out of the serial port on this PV+. No matter...
4,107
Hello gentlemen. First time posting here and I'm pretty green with programming so I was hoping for some assistance. I'm trying to connect to...
14,534
I know I can poll a modbus device using the panelview serial port... can I then take that data and pass it on to my contrologix plc some kind of...
4,270
