Parameter download over profibus with Danfoss VLT2800
Werner
Apr 2005
IJsselstein
336
Is it possible to program the parameters of an Danfoss VLT2800 over a profibus network? And if so how can this be done?
One method is to create a hardware config that includes parameter channels as well as process data channels in the address space for the drive (these are referred to as PPO types when using Siemens MasterDrives for example). You would then need to refer to the drive manual which should tell you the protocol for transferring parameters. Contact the drive supplier, they may have some function blocks already written for Step 7
i m facing the problem of troubleshooting of vlt2800 inverter.it indicates the "Error 37(communication fault between control card and bmc)" how i do to rectifeing the problem?
This is probably aimed at Jesper. I have a S7 300 with a Simocode pro c motor controller connected on profibus DP. How can I detect if a new...
12,182
If a parameter is loaded by the HMI to say DB83.DBW132 and I go to the DB and find this parameter but when I use goto location there is no...
1,904
Hello, I am trying to get all of the parameters backed up for our 12 Danfoss VLT 5000 drives. We are upgrading to FC-302 drives and I would like...
7,567
i am having some problem with control techniques make commander sk drive. i wants to download the application drive parameter and the SM...
2,404
Hello all, I am currently trying to program a PowerFlex 525, version 7.0. We had a power outage recently and when the power was restored, the...
255
