Parker AC10 VFD - control over modbus
rQx
Oct 2010
Trelleborg
1,051
Hi!
I'm not to good at communications so I wanted to practise my skills and control a Parker AC10 VFD over modbus. I go at the problem in three steps.
1. Use parker program that control the AC10 over modbus and that is also return the string that is send.
2. Use simply modbus rtu master to see if I can control it with external program.
3. Use s7-1200 to control it.
Step1: I can send commands using the program and change the speed of the drive.
Step2: I use simply mobus and send commands to the VFD. I confirm that the string that is send is the exact same as in step 1 but it won't work.
Step3: Need to complete step 2 first.
I attach screenshots of the situation and maybe someone can assist me in someway.
As you can see I get diffrent errors and diffrent responses. Sometimes no respond at all and get time out after 5 sec. And sometimes I get response 03=illegal data value.
But as you also see I send the exact same string to the VFD. Is there something fishy with the simply modbus tool?
My thought was to verify that the communication is working with a simple 3rd party tool. So when I go on to controlling the with the PLC I can focus on troubleshooting the PLC part. Maybe I'm doing it wrong here?
/Tim
I'm working with AC10 Drive 1KW 3x400V. I configured it running in Torque Control Mode. But it's not work. The speed's not smooth, when I increase...
1,342
Has anyone found a way to convert/replace/update the firmware on old Parker TS80xx series HMIs (i.e. TS8010, TS8006, etc) to accept Crimson...
121
Dear all, we have a couple of SSD 637 servo drives that need to communicate trough easyrider. On the parker website you can download easyrider...
525
Hy everyone, I have Parker DC Drive (590+). in ints manual there is mentioned about P3 port which is based on (RS-232) communication. I want to...
915
So my distributor convinced me to try this card out instead of the Ethernet I/P card this is for the 690 and 590 drives that allow for...
2,241
