Parker ssd drive 690 series
patil.inst
Jul 2011
india
Dear All,
I am using parker 690series drive.
I am using modbus rtu protocol.
Configuration used: Laptop-RS232 to RS485 converter- Drive.
Settings kept in drive are:
Modbus rtu,RS485,parity-none,baud rate-9600.
Mode: 2-wire
In order to check modbus RTU address area i m using Modscan 32 software.
However i am getting error Invalid slave response.
Led indication on drive: Network led flashing.
(Its a new drive, i have tested it on 2 drives both new)
How to check? I do not want to check through dse lite software. It works.
I will communicate drive with third party controller.
Dear all, we have a couple of SSD 637 servo drives that need to communicate trough easyrider. On the parker website you can download easyrider...
515
What is the best velocity command resolution I can hope to get with a Parker/SSD 890 drive receiving a velocity command from a plc over...
1,595
Does anybody have any knowledge of oddities with the SSD 890 AC Drives? Both compact/bookshelf, and monstrous stand alone ones have the habit of...
4,891
I'm working with AC10 Drive 1KW 3x400V. I configured it running in Torque Control Mode. But it's not work. The speed's not smooth, when I increase...
1,340
Hy everyone, I have Parker DC Drive (590+). in ints manual there is mentioned about P3 port which is based on (RS-232) communication. I want to...
911
