Parker SSD RedLion DSI3 Crimson 3 Gateway Blocks Export/Xref
MattReardon
Jul 2006
Swansea
28
I'm working with Parker SSD DSI3 which is Crimson 3 in another guise. I've created lots of gateway blocks and as you do attached tags to them. I want to be able to find & reverse find what tag is attached to what gateway block. If I export the tag database there is no record of it being attached to a particular gateway block bit/word etc.
Other than doing a Find Usage on every tag to see if that tag has been attached to the gateway block or scrolling through the whole gateway block configuration, I can't find a way of exporting the gateway blocks so I can do an easy Excel sort to see if I've duplicated any tags.
There must be a way. Surely it's a fundamental function to find out where your tags are attached/used?
Dear all, we have a couple of SSD 637 servo drives that need to communicate trough easyrider. On the parker website you can download easyrider...
515
Hy everyone, I have Parker DC Drive (590+). in ints manual there is mentioned about P3 port which is based on (RS-232) communication. I want to...
907
What is the best velocity command resolution I can hope to get with a Parker/SSD 890 drive receiving a velocity command from a plc over...
1,593
Does anybody have any knowledge of oddities with the SSD 890 AC Drives? Both compact/bookshelf, and monstrous stand alone ones have the habit of...
4,890
I'm working with AC10 Drive 1KW 3x400V. I configured it running in Torque Control Mode. But it's not work. The speed's not smooth, when I increase...
1,337
