Part Tracking using Omron Cp1EL
muzzamilbaig
Jul 2015
Manchester
Hi All,
I am trying to track rejected parts on a conveyor system.
I am using a camera to mark the bad label and then a BSL to track when it gets applied on to the bottle.
The problem I am facing is when the bottles is applied with the label the bottle is sensed before the reject shute but how do I reject the bottle with the bad label?
I have tried using a second BSL but since it is not clear which bottle will be at the reject shute it doesn't work.
Please help
Hi Garry,
Thanks for your reply.
The issue is that the bottles are not equally spaced or the number of bottles at one particular instance is not certain hence using one single output of the bit shift register is not feasible.
I would increase the frequency of the pulses on the conveyor and cascade the BSL instruction over several registers.
In the Omron controller there is a SHIFT REGISTER: SFT(010) instruction that can be used over multiple words.
http://industrial.omron.com.br/uploads/arquivos/CP1L(H)_2007_W451-E1-03_PROGRAMACAO.pdf
With the increase of conveyor pulses this will put several '1's in the shift register to track. Remember that the pulses and distance on the conveyor are related. The more pulses per distance on the conveyor will detect bottles closer together or apart.
Regards,
Garry
http://www.accautomation.ca
Sometimes to take decisions on a process based on some condition that happened in a previous stage in the process, A typical Example is Sorting...
3,944
Looking for some insight for tracking multiple parts on a conveyor. The conveyor stretch is 150 feet long with a prox at beginning. From there...
4,009
I am working on a project in which I will be tracking multiple parts on a conveyor with specific positions where the parts are marked. The...
3,421
Good evening, Here's something I've been pondering for a few weeks but have not found the time to test. Maybe someone has a better idea and can...
6,548
Hello guys, I have an application where up to 10 fixtures are transported On a conveyor system. Each fixture goes through a series of 7...
1,996
