Passive Homing in Kinetix 6000
Apr 2014
Vadodara
49
Hello All,
Thanks in advance..
Friends in my working premises several kinetix 6000 drive were configured, in which few drives were having active homing and few have passive homing..
For active homing, i understood that whenever we give homing sequence at that time, axis moves to get the reference value generally by proximity position and then reach the home position...
But for passive homing I had gone through the various definitions but not able to find out that actually what happens when passive homing sequence is given to respective drive...
The way it was explained to me is the drive homes itself with the absolute encoder. It then runs incrementally rather than rechecking it's position absolutely.
The reason I know this is we had issues with a K6000 system loosing position which turned out to be firmware related.
Active Homing - the drive will move (it will become active) as part of the built in homing sequence.
Passive Homing - the drive will not move as part of the homing command. This could be used if you have a programmed homing sequence that will get the motor in position and then passively set that position as home or if you want an operator to manually position the motor and then set that current position as home or...... With passive homing, something esle needs to position the motor - the Homing Command just sets that position as home - it will not cause any motion to occur.
Thanks friends for your reply..
@kekrahulik - Means the current position of motor become home position as soon as, I give the home sequence command... and what about the value of actual position tag of the axis, after giving home sequence..will this value also get changed as per homing condition
I have written the routine with MAM and MAS stopping the axis when it sees a prox input, then I use the MAH command with axis set to passive and...
2,859
In my S120 drive I do passive homing of an axis, because the movement is continious but I could not find the exact modulus due to many chains...
6,526
Hi, I have a device which is giving out a 4 -20mA signal but the ADC's on the PLC channel do not match. The supplier is saying the channel needs...
771
Can you wire a 1756IF8 analog input card for passive and active instruments at the same time or do they have to be separated. Such as wire 1 card...
5,030
My basic question is, what is a passive tap on an RS-232 line, and what is a derivation cable? It sounds like a passive tap would just be wires...
2,935
