Password protect a button in Factory talk view ?
passwordg
Aug 2011
South Carolina
224
Is that possible ?
I figured out how to lock a specific screen using security levels but I'm not sure how to lock a single element on a page.
I'm using a panelview plus.
You can use the security level of the user to set the Visibility of the object. So if the user has code B then display the button if they don't have B then it is not visible.
Use this expression in the Animation>Visibility of the button to allow security code A access
Code:
CurrentUserHasCode( A )
If you do use the visibility method, it's best to also put an image (grayed out version) of the button behind; could also use a button that is not assigned tags. When your secure button is hidden/invisible then at least the operator can see that a button should be there but they do not have access.
In FTView ME 8.20 you can use the signature feature on buttons, but that can get annoying to force a user password each time you use the button.
... it's best to also put an image (grayed out version) of the button behind; could also use a button that is not assigned tags. When your secure button is hidden/invisible then at least the operator can see that a button should be there but they do not have access.
This guy gets it! I HATE visibility that just disappears leaving you with no idea of functionality that actually exists.
8.2 has a disable tab on buttons. This will grey out the button like Windows.
Yes, FTView SE has a disable tab; but does not have the Signature feature.
FTView ME has the Signature feature, but does not have the disable tab.
Even the same button objects in FTViewME that have the signature feature (maintained PB, latched PB, numeric input) do not have that tab when used in FTViewSE.
...go figure?!?
so im working in CCW with a Panelview 800 and i would like to set it so that the GoToConfig button is only accessible by certain users. In the...
4,907
Hi, I'm currently in the process of locking down a program, I have managed to set passwords for FB's and WS but can't seem to find a way of...
1,781
Hi I'm trying to re-program a Mitsubishi FX0-20MR-ES plc but when i Initiate transfer from GX developer it keeps asking for an 8 digit Hexi...
2,088
Hey, folks, me again. I have an AB Panelview 800, using CCW standard edition V. 10.00, with RS 5000 V. 20.04 in a 1769-L18ER. On this job, there...
4,654
Hello everybody, I've got a problem concerning the creation of pages for a PanelView 1500 by using the RSView STUDIO software. I'd like to create...
2,219
