PC Board Output
ktmtragic
Jan 2013
Sydney
92
I have a problem I hope you guys can help with. I have a circuit board that is used to control an industrial washing machine. The outputs from the board are transistor and should be connected to a Variable speed drive. The machine I am working on has 5 motors for different speeds. (No I can't use 1 motor) The paperwork indicates the outputs are digital . Is there any way I can interface these with slave relays?
Thanks:confused:
Yes, depending on the current-switching capacity of the board output transisitors, you could use that output to drive a relay with the same coil voltage as the transisitor output. Solid-state relays may be the best type, because they usually require less current to power up.
do you have a diagram?
check if the transistors are 5 volt or open collector.
what voltage are the inputs of the VFD.
Hello everyone I have a Siemens S7-300 CPU 315-2DP, CP343-2P and ASI module .AC2459 I want to using it for test input output . as show in below...
18
4,309
Experts, I have an issue with an Allen Bradley SLC-500 Output Board. The PLC is going through it ladder logic correctly and the Output terminal...
4,111
Hi all I am having some trouble working out the address of the analog output for my 313C S7 CPU. The analog input seem to be correct at PIW 752...
11,266
Hello, recently I saw a graphic from any Rockwell App, I cant identify which one is. Attached a SS. Its used to see dashboard from datapoints and...
137
Hi all, I am trying to do Modbus communications via the CB1241 RS485 Communication Board on a Siemens S71200 PLC. I am using a 1215C CPU. After...
270
