PC Communication with CPU944 using SI2
Zazu
Oct 2003
Hello,
I try to make communication with CPU944 using SI2 serial adapter through a RS232 TTY adapter cable.I use 3964(R) procedure.The comunication is able to be initialized but i did'n t receive any valid data message from the CPU944.I received only ETX DLE which meant that is an end of transmision.When i wish to acces a DB with DW , the message which should contain the data is empty.
Is possible to be some special settings for SI2 ?
Any suggestion is really apreciated.
Thanks in advance,
Hi all. I have a Modbus ProSoft module in my setup with a capability of 30 clients (0-29), which I'm trying to monitor the Ethernet Connection...
34
Hi folks, I have a Controllogix in communication with a zigbee coordinator using Logix AIO for modbus tcp. This zigbee coordinator have 3 slaves...
167
Hello, i am using profibus as communication between plc and fanuc arm. I can easily send inputs from plc to arm, but i can't monitor any outputs...
46
I have Woodward Controller EASYGEN-3500XT and Phoenixcontact make IO CAN-CUPLER part no: 2702230, Analog Input card: 2861412, Analog Output Card ...
47
Hello Everyone, I have a issue with communication between two different PLCs. So here is the facts, The Master PLC is Guard Logix 5069 with IP...
112
