Permanent magnet dc servo
roxusa
Nov 2008
NJ
994
I have 2 permanent magnet 4 phase dc servos driving a cut off knife each level
OEM propitiatory (Marquip) with their drives. I have one level not working motors will shake and hum before overheating. Their test on motor is with an LCR Meter to measure Inductive Capacitance on a 20mH scale and the motor phases should be between 14.13mH & 19.63mH. I have one phase on one motor at 7.48mH and the other motor has one phase at 2.34mH and one phase at 7.37mH
My question is what am I measuring and how does this affect it
I have an OEM tech coming in on weekend to look at system but was wondering if this could be my problem. Thanks
Sounds like a bad servo motor. One thing that you've got to watch out for is overheating the magnets in a PM servo. They lose their magnetism, overheat, and then burn the windings.
They should be connected in either delta or wye, so your impedance should be identical.
Hello everyone, I'm new to the world of servos. And now I'm facing the next problem: I have a SEW Movidrive MDX61B and an Indramat MAC071C...
1,537
I can't seem to increase torque to the desired level w/o the motor just sitting there shaking itself to death. I can only get 80 foot lbs after...
23
4,852
Some VFDs support permanent magnet motors. For instance ABB ACS355. Has anyone tried using anything like this? What VFD / motor did you use...
7,513
Hello I'm wondering if their is so many synchrone permanent magnet motor manufacturer like Emerson Dyneo (LSRPM etc) Can someone know another...
4,186
Hi All Anyone know of a manufacturer of AC PM motors (in the 1.1KW to 5.5KW range) Fairly open question, granted, but I'm new to PM. TIA Pp
3,255
