pG monitoring with s7 300 cpu* getting hanged/delay in the programme
nijaseng
Apr 2008
New Delhi
20
guys. I have connected PG to an 317 2dp s7 cpu, after that i have started to monitor two to three function blocks at a time.then some of the actions in the feild was getting mismatched ie actions are getting delay.Due to this machine could not run properly. when i cancel the online function it was getting ok. what should be the reason for that .pls guide me.
And one more problem is that when i was tried to force some flags(m) from a vat, it is saying that password protected(ACCESS RIGHTS)
Please help me
reply
We are using a PLC Siemens S7 315 2 DP with some inverters Siemens G120C (around 7 pieces) and Micromaster 440 at profibus network and around 4 gateway profibus/ASI network.
This system work's present no problem until we needs to start to monitoring the plc for a maintenance problem for example. Then, the system start's to present some problems until to stop the monitoring.
I think the plc need to be replace for a large plc, like a 317 cpu.
Thanks for you answer and try to help us.
Willian
It is possible to monitoring the ladder via notebook in an S7 300 ET200U profibus. If possible, how?
1,899
Hi all, On site the other day monitoring a program, and yet again the display was not updating quick enough for me to visualise the ladder...
19
6,931
Hi all. I have a Modbus ProSoft module in my setup with a capability of 30 clients (0-29), which I'm trying to monitor the Ethernet Connection...
43
Hello everyone! I need to connect to a DL205-1 CPU and, as far as I know, I need to use DirectSOFT 6 software for the connection. Is anyone...
77
Our punch press has a SLC500 with HELM weight module (HM-604-WM) for tonnage monitoring. The operator enters the weight range on the HMI, which is...
223
