Phoenix Plc help
Need more specific information. Presumably you're controlling something with that 4-20 signal. What in your logic is controlling the signals value?
What specifically is your stopping point? IO module configuration? Scaling function blocks? Phoenix does not scale through the module properties as with RSL5k.
A "Phoenix PLC 191" is probably one of the small "Inline" family of logic controllers from Phoenix Contact, specifically the ILC 191 ETH 2TX or the ILC 191 ME/AN.
If OP can give some information about how she has configured PCWorx for the analog module and what kind of application she is trying to create, folks who use PCWorx for this or other Phoenix controllers may be able to help her understand the analog module and its related configuration and scaling.
while compiling the program the error occurs: '' Data type 'Analog_udt_A04_8_OUT define more than once, in PC WORKX software of phoenix plc
1,144
how to creat functions and funtional blocks in plc workx
1,351
i am creating a function block in my program then i create it but when i call it i dont know how to give the function block input and outputs plz...
1,841
dear all i have phoenix plc in running plant ilc 155 eth. I am face the problem of retained the previous program or going to fault mode...
1,710
how to communicate and configure Wireless module - FLM BT BS 3 - 2736770 and Wireless module - FLM BT BS 3 - 2736770 in PC workx plx help...
1,156
