Photosensor Advice
BigTuna
Mar 2014
Nova Scotia
Any photosensor experts out there? My first photo sensor project and I need some advice.
The application is to detect ice falling in an ice pen (10x10 room with ice falling periodically from an ice machine in ceiling). I'm looking at the following sensor:
http://www.automationdirect.com/adc/Shopping/Catalog/Sensors_-z-_Encoders/Photoelectric_Sensors/18mm_Round_-_IP69K_%28Harsh_Duty_-z-_Food_-a-_Bev.%29_%28FF_Series%29/Polarized_Retroreflective_%28FFRP_-z-_FFRN_Series%29/FFRP-BN-1E
Will that do the trick? I went with the polarized to ensure I get the distance.
Any opinions / suggestions / alternatives would be much appreciated.
Thanks!
With that you will receive an 84 mm reflector. The PE will aim at the reflector to receive light back. You can wire it for a signal if a reflection (of the proper polarization) is being seen or if no reflection is being seen. The sensing area is a cone from a point on the face of the PE to the outside of the reflector.
The polarized retroreflector should see ice in that area since, even if it is very clear, it will not return the same polarization of light as the reflector. You may have to test somewhat.
There are many highly experienced folks on this forum. I have not had to sense ice, so I will defer to their expertise.
I've used hundreds of photosensors but I still end up talking to my Banner or Pepperl&Fuchs Apps Engineer when I have a head scratcher. The big advantage of going to them: if it doesn't work, they go to extremes to give me something that finally does work. The apps engineers are a great resource: know their products and stand behind them. Stand on the shoulders of giants...
Maybe a stretch to call this a PLC question, but it does connect to a PLC input. I have two German switches: Sick WL9LG-3P2232 And a...
113
At some time in the past, someone told me about a card that you could hold in the path of an infrared photo emitter that made the beam visible...
1,445
I am not sure why this is requested, but it was asked. Currently I have one PLC , with one output to a relay, turning on a field equipment (just...
219
Hi , Where i can find Mitsubishi PLC Card end of line & replacement model details. i am looking for Q02CPU replacement model. Please advice. thanks
128
Hi everyone id like to start by saying im not a PLC programmer so my technical terminology is limited. i would like advice on what software is...
299
