PID Compact Logix
irondesk40
Jan 2008
nc
630
Have a application I have been working on today using a compact logix to control temperature of molds. I am using a PID to get the Preset values for some timers that are being used to control solid state relays for the heaters.
I can heat the molds to the desired temperature and maintain the exact temperature within 1 degree F. What is happening is that as the mold is heating up the mold temperature will overshoot about 10 degrees but then will settle down and the PID maintains the desired temperature.
I have played around and found that if I add code to turn the heaters fully on all the time until I get with 95% of the desired temperature and then let the PID take control then it will only overshoot about 6 degrees.
Any advice on what to tweak in the PID to keep the overshoot to a minimum?
This equipment did have Fuji Temperature controllers operating in PID mode and they would overshoot about 10-15 degrees as well, but with the PLC I am trying to see if I can get the overshoot down to a minimum.
Hello all! First official post here... have been using the site for help but managed to find existing threads to help with all previous issues...
1,209
Hello. I am trying to figure out how to setup a PID in Control Logix 1769 Controller in a way that it would control a drive speed by sending...
1,627
Have some machines that i used a micrologix 1400 plc and using thermocouple inputs and outputs to control solid state relays to maintain the...
3,654
If anyone could help it would be appreicated....Thanks....
2,752
My compact logix processor has 15 temp pid loops but looking in the program there is only one pid function block? How can this be? Can you run...
4,119
