PID Control for Inverter controlled motor
miketheb
Oct 2008
Peterborough
Hi All
Has anyone used the PID function for controlling an inverter controlled motor to give set lengths of travel through a gearbox drive i.e.
Motor needs to run for say 10000 pulses (from an encoder using high speed input) and then come to a slow stop, the length dependant on the number of pulses.
Then repeat with pulses set by a programme register?
I assume it can be done and am about to try ~ any issues likely to cause a problem. PLC is Mitsi FX2N
Regards
Mike
Assuming your inverter does not have a positioning front end, you will need a single axis controller for your PLC. Take the speed and direction outputs to your inverter.
I have S7 1512C controler for controlling 48 PID temperature loop, the output is PWM. Please I need the best, most efficient way to write the...
624
Hi all, I'm having trouble solving a problem I've been working on for several months, and thought you might like a stab at it. The machine runs...
22
967
How can I connect PID Output to a valve. In ladder logic program is there any logic do I want to add between valve and PID? PV=SP What will be the...
424
I am setting up control for Hypochlorite dosing. The easy part is the dosing calculation for flow pacing but I would also like to setup trimming...
954
Hey guys! I'm a newbie in the control area, so I'm gonna drop some thoughts here... We want to control the opening of big silos (about 1900...
1,494
