PID Faceplate Setup - C-More & SOLO temp controller - "Mode Bit" question
rguimond
Jul 2009
Escuminac
666
I'm trying to set up four PID Faceplate Bar Meters using C-More Ver 2.77 to communicate with a network of four SOLO 4848-CR temperature controllers. I have the network running and can read parameters such as PV, SP, Output, etc. However, I can't find the memory address for "Mode Bit" in the "Mode and Alarm Tag" box in the PID Faceplate Bar Meter set up box. I assume it will display Auto or Manual.
I'm using ther AutomationDirest SOLO Temp Controller driver, which gives me a list of pre-determine tag names to select from. From the list, i have been unable to determien which tag to use for the "Mode Bit".
Can anyone help?
I have a PID instruction in the ladder logic with tag name pid1 I was trying to follow the youtube to create the PIDE faceplate, however, the...
1,181
Hi all I am trying to create a faceplate to set pid parameters for fb41 when I assign dynamic property I cannot pick a time for the data format...
2,999
82
Hello, I have a motor that we are sending a RPM Speed Output from 0-100% to the VFD. However, the Motor HP needs to be limited to 6000 HP and the...
91
I have S7 1512C controler for controlling 48 PID temperature loop, the output is PWM. Please I need the best, most efficient way to write the...
611
