PID for proportional air valve
kamenges said:
Ideally you would be able to quantify what is causing your loss in the first place.
Keith
I was curious why we were not promting Alex Pel to quantify why it was not working when I first read this thread.
Alex Pel said:
When gun is open I add 200 mBar, It works much better: within 700 – 900
I am also curious if this is oscillation, droop, or spikes at the ends of the cycle.
Alex Pel,
If I'm understanding you correctly. The air pressure rises quickly at the last part of the cycle. This would have to be when the gun shuts off and the regulating valve signal is just being switched from 800
mBar + 200mBar to just 800mBar. If this doesn't cause any problems just leave it the way it is. If it causes problems can you switch back a couple of hundreths of a second earlier before the gun shuts off?
All this recent talk of PID brought me back to an issue I was looking at a few months ago. My next project will involve cycling a valve to provide...
2,633
I want to use a proportional valve for controlling the pressure in a tank/cylinder. In our design we need to have two profiles for PC valve. The...
2,071
I'm trying to improve tuning on Watlow 'Series PD' PID controller and am using some tuning guides to help. Application is simple temperature...
7,092
I found this question in my Personal Message box ... not sure why the sender didn’t just post it to the open forum ... the questions are valid and...
7,852
Hi. First let me say I've been reading this board almost daily since last July when I first started PLC programming, and have found it to be a...
18,267
