PID Loop Update time and external trigger
leitmotif
Nov 2004
Seattle Wa. USA
3,680
In another post
http://www.plctalk.net/qanda/showthread.php?t=2473
post #4
Ron Beaurford said
"And THAT - dear readers - is why I keep harping-harping-harping on maintaining that all important relationship between the PID’s internal “Loop Update Time” setting and the scheduling of the external “trigger” event. If those two settings are not kept in sync, then heaven help you - I can’t."
OK so you have two clocks controlling this - so they must be in synch -
QUESTION why not use only one clock ie loop update time
ANSWER (mine) process may have an interval where the PID must be put on hold to allow process to change ?? For example on AB SLC 5/05 am starting to learn how to use PID to control speed of a hydraulic motor by using VFD to vayr speeed of the hydraulic pump.
When motor reverses (using solenoid actuated 4 way valve)the tach generator output reverses. I have to (choose ?) to multiply this by -1 to correct it back to a positive value. SO I think I will have to use timer to allow for time of motor reversal tand the calculation.
Have I got this right??
Dan Bentler
Hi all, splitting out from this thread because it's a somewhat different question to the original. I have to migrate some code from a Micrologix...
17
4,187
Hi all, I've been tasked with migrating a standalone control box with a Micrologix 1100 into an existing 5380 Compact Logix controller. It has a...
2,455
Today I upgraded an L55 processor with an L82, which ended up being the 2nd unsuccessful attempt but thats a different story. After starting the...
4,555
Just tuned a heating application where my natural period was 250 seconds. Everything I've read says that the loop update time should be 5-10 times...
1,641
May be my question is too childish, but can i get all the answers please? For PID of ML1400, if I right loop update as 0.02 & time mode as STI...
4,784
