MAYBE he has got it
Peter
Going to North Seattle Comm Coll -- it is the "North" portion of the Seattle Community College.
Instructors cannot know it all. I believe he does not work with AB SLC 5/05 PID instruction to be familar. Servos, amps etc etc he is a whiz.
I have thought all along that this setup is kind of goofy and the hard way to do it. But my brother who works on Boeing machine tools says this is a common setup. It does have some other apps though ie a potentially explosive gas or dust situation would be a good choice for hydraulics or pneumatics in my mind. Why put electrical there in the first place?? OK OK you gotta do lighting BUT in spray booths they mount the lites outide the glass tops which is a "safe" area.
Anyway the learning on this goofball setup will be harder and I think more valuable than a simple heater setup.
I HAVE READ the responses.
I HAVE DONE SOMETHING
I took all the info I read here and dug out the books and manuals and setup a table using EXCEL for the two input values and one output of the PID. Described them as they "come in", go to PID (as a scaled value using SCP instruct) and how they come out of PID and where they go.
All this stuff is in attd Excel file sheet PID.
ALSO in Excel file is a set of calcs to show me why you cannot use just P to control. I set up hypothetical water heater and made an assumption of heat imput and heat loss to ambient - there are some rough assumptions and it can be argued that my calcs are not in a true time frame but I had to avoid circlular logic error. It has shown me that P alone will not work. There is also a graph of the output and the control showing how the control oscillates - and man -- mine OSCILLATES. That is in sheet P no go.
Many thanks for help
Dan Bentler
Peter
Dan Bentler
