PID settings
panthripu
Mar 2004
228
hi friends
can someone suggest me the best way to tune up PID.
In my sytem i am controlling negative pressure inside a vessel by adjusting the damper position in suction duct.For last few days i observe there are lot of fluctions in the system.It seems someone played with the PID setting.I dont remember the old settings.
How should i start to ,tune up the PID again.
Your help will really be appriciated.
thanx
thanks friend
I have tried to tune it and finally i am getting oscillations with upto 14% on positve side and 18 % negative side.for one oscillation it is taking constant around 18to 20 sec.
the gain is now at .42 and integral is 5sec.
it is possible to improve it more ?if yes how to tune it better?
In microwin under tools there is a pid tune control panel..
This may be of help ?
I have no expierence of it though, just thought id mention it in case you had missed it.
I am working on dialing in the PID settings on a Furnace using RS Logix500 I know what Gain, Reset, and Rate are but I am not sure of some of the...
2,096
I have two questions: When you open the settings for the PID you have the option of doing manual and auto does manual use the values entered and...
1,756
Hi all, I am looking at a problem with an S7-200 CN (controlling a filling and sealing machine) which has a PID Loop that controls a heating...
1,837
Hi experts; I attached a image in which i set the parameters which i found from an application which is almost similar to my task. I want to know...
3,530
Hello! I am doing a project with a servo based winder with a speed regulation. Since i am a newbie at Siemens S7 i ask your guys how the CONT_C...
1,889
