PID Simulation in GX Works2
Marti9t9
Dec 2014
Dundalk
I am new to Mitsi and I'm working on a project that will use a few PID loops. I do not have the hardware in the office so I am using the simulator to test my code. All is well, except my PID loops do not seem to be executing. I have entered what I believe to be all the parameters required but the MV never moves from zero. What's stranger is, i can force the MV to a value and it doesn't get written back to zero. The routine itself is being processed and the simulator is not in a crashed state. Can PID loops be simulated like this or do I need a physical CPU? I would very much appreciate some help with this. For completeness please see below. Thanks.
PLC:Q series
Software: Gx Works2, Gx Simulator
PID commands: PIDINT and PIDCONT
82
There has been quite a lot about PID programming & simulation recently & I thought some people might like this idea, it is a bit Heath Robinson...
999
Hello, I have been developing a library of function blocks. One of the developed function blocks is the PID controller. I have created a Simulink...
2,991
Would anybody know how I can simulate the PV of a PID function using the output of the PID itself? I have seen it done before using an integrator...
2,599
Hello, I am learning Honeywell PKS on a PKS R311 virtual machine. I built a PID CM and loaded to the simulation. Does anybody know how to make...
2,202
