PID temperature control with Beckhoff EL4004
derickloo
Mar 2015
Malaysia
36
I have PID temperature control which will connect to Beckhoff EL4004(0v-10v). How I can program it to let EL4004 to control the temperature?
view
I have the PID temperature control as above. Currently the temperature is set on the controller. I need connect it to the EL4004 and write a program which user can set the temperature of each controller on the touch screen.
It might be helpful to tell us what your PID controller is, complete with full part number. I can't tell from that picture what you have. Is it capable of receiving a 0V - 10V signal, or does it have to be 4-20mA? If it can handle both, is 0 - 10V selected in the configuration menus of the controller? Have you set the controller setpoint to be controlled by the analog signal? You should be able to find all of these answers using your manual and by going through the configuration menus on the controller.
I'm totally no idea on the electrical part. I'm pure C# program developer. No electrical background. This will kill me. I'm also no idea how to program in PLC. o_O o_O o_O
http://www.taisee-scr.com.tw/TEMP-TA.htm
This is what I can found for the Taisee PID temperature controller but it's in Chinese version. Can't find EN version. I think the controller can accept 0v-10v and 4 - 20mA.
I have S7 1512C controler for controlling 48 PID temperature loop, the output is PWM. Please I need the best, most efficient way to write the...
608
I'm doing PID temperature controller using PLC. I'm doing a cascaded P, and PI controller of both temperature set points. My question is how...
1,735
go to work on this again this morning. I have attached the file and have a question that i can not figure out. When monitoring the temperature i...
3,542
Dear friends I'm working on a project to control the furnace temperature. As you see in the attached image,The operator enters the...
3,933
Hi Everyone. I have been reading through the forums, and I have learned a lot! I do have a specific question that I couldn't find. I have a...
5,110
