jhunter1993
Hello,
Long time listener to these pages first time caller.
I have a facility with 2 of my company's units there. They have been running for about 4 years. They are compressors so there are 2 PID's one that controls a recycle valve to control discharge pressure/ flow and another one that controls motor speed.
Everything has been working well for about 4 years then all the sudden one of the units started acting weird (the site says) and now the other one. The speed control is suppost to start the units an minimum speed which would be 4mA output or 950 rpm and has more gas flow is needed the motor speeds up. 1 of the units motors runs at 1200rpm and the other at 1800rpm all the time now, come to find it its because the PIDE isn't outputing a CV and the VFD's has a setpoint to bring the motors to a base speed if signal was lost (they just happened to be different).
Anyways, I cannot figure out why the PID isnt sending out a CV I checked and its status is OK and I have no errors. When the unit is running it is calculating the correct E it just doesnt do anything about it. The other PIDE in the program is having no issues and seems to be set up pretty much the exact same way (a few differences obviosly).
I've called some old buddies and we couldn't come up with anything, especially since it worked for almost 4 years.
I attached the L5k file and a picture of the block while the unit was running. Any ideas will be greatly apprieciated.
