pin out for Sq. D telemecanique TSX07
richensel
Jul 2003
I am missing the communication cable to connect my PC to my Square D telemecanique TSX07 PLC. I have both ends (the PLC side takes a mini DIN 8 pin male) but need to know which pins should connect where.
Any ideas, I struck out on SquareD's web site.
Thanks, good info, but.... the cable I had connected using a DB-9 connector and this only tells me how to wire a DB-25 connector.
That may not be a big deal, but I don't kow how to work around.
Anything else?
If the comms cable is RS422 or RS232 you might be able to find the answer at this web site
That site is a good source of information for cable's and connector pin outs.
Thanks to whoever posted that link before, sorry I can't remember who it was.
Paul
Dear friends i Need pin out diagram of cable TSX PCX 1031 for Twido PLC.
5,236
Hello: I have to connect a RS232 Modbus RTU slave that only has Tx, Rx and GND signals to a Modbus RTU master. However, all RS232 to RS485...
249
Hi All, I came up with this for ramping the PWM pin on the micro 820. I'm new to ladder logic so I am not sure if this will even work? Once...
367
MELSEC A RS422 (25pin) <> iQR C24 Serial RS232 (9pin) - Simple PLC Communication Communication from a MELSEC-A Series CPU (RS-422 – DB 25 Pin)...
1,053
M12 sensor plugs are widely used. I'm about making my own CAD symbols for sensor connections, and I'm not sure about including pin #5, which is...
1,516
