Pin out of serial cable on a Control logix 1761 <-> Panel View 600
edwinmart
Jun 2006
Santo Domingo
31
I will like to make a cable to connect a Control Logix 1761 with a Panel View 600 I have two DB9 - DB25 cables which I will sicrifice to make the cable.
No need to make your own cable.
ControlLogix serial ports are "DTE" type. PanelView (both Standard and Plus) serial ports are "DCE" type.
Therefore you need an ordinary female-to-female 9-pin straight-through cable to connect them together.
The pinout of the 2711-NC13 cable is shown in the RA Knowledgebase as Answer ID # 19638.
Dear friends . I have is CP5711 siemens , it is having USB cable from Laptop to CP5711 Port. but does not have a cable from Other side (serial)...
4,381
Hi, I need to make a cable to program an idec Micro 3 PLC from my PC via the serial port. Does anyone know the pinout? Any help appreciated!
6,039
MELSEC A RS422 (25pin) <> iQR C24 Serial RS232 (9pin) - Simple PLC Communication Communication from a MELSEC-A Series CPU (RS-422 – DB 25 Pin)...
1,044
We have moved out an old PLC5 rack and moved the Control to a SLC 5/04 Chassis we are going across dh+ network and serial DF1 I think, we are...
1,759
Does anyone have a pin out for the 9 pin serial port on an AB Micrologix 1500 to PC? (The comm 1 port on the PLC) Thanks in advance, Don
6,260
