(8{)} ( .)
OK Guys...
The process in question had 4 sequencer output and 4 sequencer input instructions to control 12 silos and the delivery piping to and from the silos. The sequencer instructions didn't perform a sequence, they were there for the masking capabilities.
The sequencers did the following tasks
Sequencer 1 - Silos 1-6 inlet valves
Sequencer 2 - Silos 7-12 inlet valves
Sequencer 3 - Silos 7-12 outlet valves
Sequencer 4 - Silos 1-6 outlet valves
The support logic for these things was ridiculous - align all of the inputs and outputs so that we can use the same data for both
the SQI and SQO in addition to the logic required to have the sequencer jump to the right step.
Basically, garbage...
I used no sequencers for the valve programming and grew my own for the startup and shutdown stages (since these stages were different depending on the material path).
End results:
* Smaller Code
* Servicable Code
* REALLY happy customer
* Lots of posts on PLCS.NET
Cheers,
(8{)} .)
(Yosi)
End results:
* Smaller Code
* Servicable Code
Cheers,
(8{)} .)
(Yosi)
