PLC-3 to Prosoft MVI Modbus
TRIGUY
Feb 2004
Texas
Has anyone successflly implemented ANY prosoft I/F to PLC3?
My hardware:
  • PLC-3 (not 3-10)
  • S5 Scanner
  • 1771-ASB series D Remote IO
  • MVI171-MCM(prosoft)
Background
I copied the program example for the PLC-5 provided by prosoft, using the PLC-3 instruction MVF in place of COP, and hardcoded the section of indirect logic used to calc the data block. All else follows SIMILIAR format. Data tables are duplicates.
The module configuration is downloaded and i confirmed that the port of the MVI is sending modbus command using the prosoft built in data analyzer.
The problem:
BTR/BTW responds with a status command requests( modbus command list) and increments this each time the modbus message is sent. after several messages, the BTR/BTW /EN bit hangs up and the instructions never /DN or /ER. Information exchange betwrrn BTR/BTW and MVI stops.
The Retry fail is disabled
Regards...
Hi all. This is a very specific issue. My first time with a Modbus ProSoft. Customer setup doesn't make any sense but we're stuck with it...
392
Hello, I am pulling my hair out trying to setup Modbus Master Read/Write Commands on a Prosoft MVI56E-MCM attached to a Clogixs 1756-L82E PLC. It...
1,581
Dear all, Can any one share the procedure how to configure Allenbradley PLC as modbus TCP server with DCS through Prosoft PLX31 EIP MBTCP
2,174
Hi all, Hoping someone here has experience on ProSoft modules and using them with PLC-5s to bridge the gap between the old and the new. We've...
2,118
Hi guys, I have a question about using module MVI56E-SIE to CLX frame for communication with VIPA 300S Speed7. I know that is this module...
2,708
